Engine Makes Weird Sound!!!
Old Apr 21, 2004 | 05:15 PM
joneboyy's Avatar
Car: '82 Z28 Indy pace car
Transmission: 4 speed berg warner
When I first start up my car in the morning it knocks and ticks quite loudly, I tightened my manifold and replaced my air intake pipes, but the sound still persists. Can anyone help?
Old Apr 21, 2004 | 05:24 PM
joneboyy's Avatar
... one last thing, i also just replaced the heat-riser. can u help?
Old Apr 21, 2004 | 05:28 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
i had the same problem and i tightened the head bolts and it fixed it. i dont know why the heads bein loose would cause knocking but as soon as i tightened up the bolts the knocking went away. that might be the case for you im not positive though.
Old Apr 21, 2004 | 05:30 PM
joneboyy's Avatar
thanks a bunch ill give it a try...
Old Apr 28, 2004 | 08:40 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
Every time that happens to me I end up droppin a new motor into it....sure its not a rod knock??
Old May 1, 2004 | 07:06 PM
Savannah Dan's Avatar
If its a LT1, they tick and tap. Nothing wrong. If it's a LT1 built to a 383, the pistons slap till it warms up.
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
