305 to 350 swap
Old May 2, 2004 | 12:08 AM
dave8888's Avatar
305 to 350 swap
i own an '88 305 Tbi camaro and i want to swap to a 350 engine though. i wanted to know if someone knows how to go about putting in a carburated 350 what with the sensors and computer for the throttle body. i'd like to put in a fourbarrel carb but im concerned on what changes ill have to do on the electronics for the thing to work right. excuse my lack of knowledge but i also need to know if the 350 will fit and run right on my original 305 transmission and if any changes to the rear end would have to be done.
I'd appreciate some imput on these topics. Dave.
Old May 2, 2004 | 12:15 AM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
welcome to the boards
welcome, and I'm not trying to be rude or anything but there is a search button. as far as the engine and trans fitting in the car, it will work, I haven't done a swap involveing a carb (just tbi). hope this helps a little
Old May 2, 2004 | 12:37 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I did exactly what you did. Even the same year car.
You need:
carb
carb intake manifold
fuel pressure regulator
vacuum advance hei distributor
and thats pretty much it. Plus odds and ends but there is a nice tech article about this swap.
You do not have to worry about the computer since it will no longer do anything.
And goingf from a 305 to a 350 is a direct swap. Nothing needed.
Old May 2, 2004 | 09:51 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
do you need to pass emissions? do you think the bare carb system can pass emissions? anybody else out there pass emissions with a non-computer carb 350?
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
