putting the 327 in my car...
Old Apr 26, 2004 | 04:57 PM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
ok i am currently rebuilding a 327 out of a early 60's impala..its a small journal 327 block..
i got a set of 416 casting heads from friend of mine and am thinking of bolting them up..depends on the cam ect..
what needs to bolt up..the trans and the engine....what problems will there be with the 153t flywheel and the block not having the right holes for the starter?..
anyone who has done a small block engine swap..what else should i look out for?...
Old Apr 26, 2004 | 06:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Be careful with the dipstick. Its causes problems, unless you have headers.
You will probably have to drill and tap a new hole in the block for your starter. I had to to make a '79 350 work.
If you are using a T5 with a mechanical clutch linkage, make sure there is a hole in the block, above the oil filter, for the ****.
Old Apr 26, 2004 | 11:38 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
I have a 64 Impala SS with a 327, im currently restoreing it but the engine is solid, I just wanted to ask you where did you get the engine and how much did it cost, the engine in my impala is a 327 crate but I paid 1500 for the whole car and the engine was brand new with like 50 Miles on it.
Old Apr 27, 2004 | 06:04 AM
Car: 84 Trans Am
i got the short block on ebay for 150...the guy lived less than 5 miles from my house so i was able to see it before i bid and pick it up 15 mintues after the auction ended... the guy only put 2,000 miles on the engine but said it smoked...i bought the engine to build myself anyway...
the only reason the guy couldnt use the engine anymore was because it didnt have that hole. for the clutch cross bar..my t-5 has hydralic linkage..
ive got headers so i dont think that dipstick should be a problem..
Old Apr 27, 2004 | 03:31 PM
Car: 84 Trans Am
ok what kind of water pump do i need...i read something about needing a short water pump because it was a early pre 70's block... and my car has a long style...
if i use the short style can i use all my pullies....i am planning on keeping the a/c, p/s and alternator....
what does the computer in my car actually control..im planning on getting that jet CCC upgrade because im keeping the a/c and need the idea to bump up when it goes on....i know it costs more but i wanna keep it stock looking..
Old Apr 27, 2004 | 03:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You don't want the short style pump. If you use that, it won't fit to any of your accessories at all. The short pump is for cars older than about 1970 only, or race cars with purpose-built accessory arrangements.
You need the style that goes with your car's accesories, which is the long style. The stock 84 pump will work fine.
You'll probably need to have the late-model starter bolt hole drilled in the block.
Your existing flywheel and bell housing will bolt right up. The hydraulics will work fine.
Don't forget to put a SHORT bolt in the upper one of the 2 bolt holes on the right front of the block, between the timing cover and the fuel pump, with a little sealer on the threads.
The oil pan that's on it will not fit your chassis. You need the one out of a 70s 307, 305, 267, 350, or 400, out of a F, G, or A body. Not a truck one or a full-size car one. Must be one of those body styles.
The computer controls the fuel misture and the ignition timing; and a few other incidentals like EGR. It should require minor adjustments at most to tune it for the larger motor, as long as the cam isn't too radical.
Old Apr 27, 2004 | 04:23 PM
Car: 84 Trans Am
will a long style pump bolt to the 327 block
anything else?
Old Apr 27, 2004 | 04:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes
No
Old Apr 27, 2004 | 08:47 PM
Car: 84 Trans Am
thanks for all the help with everything....im only 17 and without a forum like this i think id totally be lost..
Old May 2, 2004 | 09:31 PM
Air_Adam's Avatar
Was in the same boat 2 years ago when I was putting a 350 in my car
Good luck!
Old May 2, 2004 | 11:23 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
Just a note on oil pans. I used a 78 350 truck motor with its stock oil pan for my mule motor while setting up scatter shield, headers, super t-10 etc.
Old May 3, 2004 | 09:26 AM
IROCZBeast's Avatar
Car: Looking For IROC
should be nice once its done. good luck with it.
p.s. your gonna need more than that 327 when i'm done with the LT1
Old May 3, 2004 | 09:51 AM
Car: 84 Trans Am
your going to need a car to put that engine you dont actually have yet in to...
engines and cars cant be bought with hopes and dreams..
Jake_92RS
Jan 28, 2020 10:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
michealleger
Aug 26, 2015 03:29 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
