88 350 into 87 GTA
Old Apr 21, 2004 | 07:40 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
88 350 into 87 GTA
Ok here is what is going on. I have a 87 GTA with no engine. It is other wise complete. It has the computer and harness. It has a digital dash.
And I have a 88 formy 350 that is my "parts car" with a good engine. This is the engine that is going into the GTA.
So I am already aware that the alt is on the other side along with the a/c . The gta will be a/c delete so no worries there. And some extra wire for the alt. But on the air intake system on the 87 gta I don't see a place for the maf that is on the 88. What do I do with it? Also will the sending units on the 88 engine work with the 87 and the digital dash. Any other problems that I will run into. I think it should be mostly a peice of cake.
Thanks brothern,
Conrad
Old Apr 22, 2004 | 10:05 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
For the MAF you can just use the snorkel setup for your 88. I am curious as to why your 87 is missing a MAF. The sending units should be the same. However I think you might need your old prom or ECM to make the digital dash work. This would depend on if the two dashboards accept the same signal.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
LilHot
Aug 19, 2015 10:02 AM
gta power
Aug 13, 2015 06:15 AM
