Moved the PCM to inside the car :)
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
After about 3 days of soldering, the computer is now inside the car, not mounted yet but saved a lot of room in the engine bay, still need to move the plugs between the AC in the engine however and put some wiring loom on it. Looks real nice now:
Picture of the custom intake setup. These were taken before I did the wiring clean up, its pretty cleaned up now, just need to pick up some wiring loom.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Nice pic of your fingers
If your PCM was going to be in the same place as mine, that ws a sheesh load of splicing
. I take it it all works. Also, If you just did a full a/c delets, there would be room
Yup, whole butt load, already ran the car, runs fine, gonna take datamaster to it tomorrow and make sure evertyhing is okay.
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i thought the ecm was in the car under the passanger side dash
or is that only in carbd cars
the thirdgen computer was called an ECM because it only controlled the engine. 4th gen computers are called PCM (powertrain control module) because they also control the transmission.
NBrehm
Aug 25, 2015 11:49 PM
AkDrifted
Aug 17, 2015 07:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
