LT1 swap and 2500 rpm idle??
Old May 6, 2004 | 07:44 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I just did an engine swap with a LT1 into a third gen and have had a 2500 rpm idle since. Ive cleaned the TB triple checked all vacum lines. I have the egr valve on the back of the intake still in with the vacum line caped off and the egr is deleted from the ecm
Ive tried everything but replace the iac valve,
Has anyone ever run into this problem before after headers or what or is there anything else i can try
Old May 6, 2004 | 08:06 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
One thing I found out the hard way is to make sure your moron cousin puts the fuel rails on tight. Check the fuel rails, I had mine dangling over the ports and had it idle at 4500-5000. Check your vacuum lines on the intake, schrader valve, AIR pump if you got it, opti vacuum if you have a vented opti, IAC, TPS.
specialized
Jun 18, 2022 09:26 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
TreDeClaw
Aug 14, 2015 06:58 PM
