Best swap for 86 transam?
Car: 1986 Pontiac Trans Am
Engine: LG4 305 4bbl
Transmission: 5 Speed
Im wanting to swap in a 400 cube or bigger engine into my 86 trans am, its a 5 speed LG4 4 bbl. What would be the best as far as ease of swap? I'd like to do a 400....not sure how hard or easy it is. Thanks..
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
330817.....400...72-80...2 Bolt
3951509....400...70-71...4 Bolt
3951509....400...74-80...2 Bolt
3951511....400...70-73...4 Bolt
Here are some casting #'s The 2 bolt blocks are tougher than the 4 bolt....if you want 4 bolt main you can use splayed caps on the 2 bolt blocks...I would also look at upgrading the heads and cam as the stock ones are good for not much!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Feb 28, 2016 03:33 PM
