Cheap engine
Old May 11, 2004 | 09:20 AM
Renegade_Brad's Avatar
Car: 1986 Pontiac Trans Am
Engine: V8 305 TPI 5.0L
Cheap engine
I have a 305 that is burning oil really bad among other things i'm sure as seeing that i only get 200 miles per 15 gallon tank. I am gonna put a 383 stroker in thise december most likely. I was wondering what would be the best way to repair the engine or if i should just go and buy a new/used cheap working engine. The engine is not gonna be in the car very long so i don't need something that is gonna last 5 years or something but until december.
Old May 11, 2004 | 09:25 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Typically replacing the valve stem seals makes a big difference. It can be done without removing the heads from the engine.
While you're at it, replace the intake manifold gaskets. They've been known to let oil into the intake ports.
If those two don't help, get a cheap JY engine with a warranty to get you by. Or, keep adding oil and cleaning spark plugs.
Old May 11, 2004 | 09:38 AM
it also gets really hot about 250 when i am driving in town. I don't use the air conditioner and i always keep enough oil in it. I am gonna try and drive it about 300 miles at the end of this month and am wondering if I should be doing this with the way it burns oil.
Old May 11, 2004 | 07:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
be careful running that hot you may have or end up with a blown head gasket too
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
