5.3 vortec to 700r-4
Old May 11, 2004 | 02:48 PM
roughneck's Avatar
Please help. I would like to swap out my 84 model 350 and replace it with a vortec 5.3 or 6.0. I can get a wiring harness from painless, but I was wondering if anyone knows were to get an adapter plate to mate the vortec 5.3 to a 700r-4 trans.
Old May 11, 2004 | 07:14 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
wow now that swap sounds cool have you checked with b&m they sell some adapters to mate transmissions to different engines...
Old May 11, 2004 | 11:16 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Are you sure the vortec engines use a different bellhousing? They use a 4L60E or a 4L80E if think, and I'm pretty sure the bellhousings are the same as a Gen 1/2 SBC. I could be wrong though, it has happeend once or twice before.
Old May 12, 2004 | 08:31 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I know the bellhousing has the same pattern but:
the LS family of motors uses a metric bolt to attach to the bellhousing, no problem there, just get them instead of the standard bolts.
they also only use partial number of mounting bolts. I believe the middle bolt(of the three) on the passenger side is not used becuase the cylinder is so close to the back of the block.
this is the biggest gotcha-I don't know if the crank centerlines are the same. You would need to find that out. If that doesn't check out, then you could just run an LS 4l60E, and let the LS ecm control the trans as well.
Old May 12, 2004 | 11:53 AM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
It takes a special bushing to put the torque converter in the right place. Don't try to tap the bolt hole that isn't there. You are assured to tap right into the number 8 cylinder.
Old May 16, 2004 | 07:41 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
No adapter plate is needed. The Gen III torque converter is needed however.
Leave out top right bolt and you're good.
ZZ3Astro
Aug 13, 2019 12:57 AM
Quzyle
Oct 15, 2015 03:35 PM
customblackbird
Oct 1, 2015 04:30 PM
monte87cortez
Sep 26, 2015 08:10 PM
Amillionoh7
Sep 11, 2015 11:36 AM
