TPI Swap to a carb motor??
Old May 13, 2004 | 01:57 PM
RicksRedNomad's Avatar
Car: Several
Engine: Several
Transmission: several
I have a 87 Vert with stock carb motor with 78000 mile's on it and i have the complete TPI system from a 86 305 with all under hood wiring ad ecm, Will this work on the stock carb 305 engine??
If so what other part's will i need and will this be a fairly straight forward swap, Should any changes be made to the stock 305??
Thanks in Advance
Old May 13, 2004 | 02:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'll need an in-tank fuel pump or similar aftermarket in-line pump, and the high pressure fuel lines up by the engine. You'll probably need the associated electric pump relays and switches, since they often aren't included in the underhood harness & ECM.
A better cam would be a good idea while you're at it. Go for a nice aftermarket factory-type roller such as Crane or Comp compucams. Of course, better valve springs wouldn't be a bad idea if you do that.
Old May 13, 2004 | 02:14 PM
five7kid's Avatar
Oh, the '87 heads and '86 base will have a different bolt angle for the center two bolts on each side of the intake. You might be able to trade someone for their '87-'89 base on the classifieds.
Old May 13, 2004 | 02:15 PM
five7kid's Avatar
Did I mention throttle, cruise, and TV cables? Bet I didn't.
Upper radiator hose, heater hoses... Never mind, those are "standard" replace-when-modifying parts...
Old May 14, 2004 | 11:18 PM
Car: Several
Engine: Several
five7kid, Thanks for your help and input on this. Would a tank from 89 rs that had the 2.8 v-6 with fuel injection have the right pump and lines for this use??
Old May 14, 2004 | 11:31 PM
five7kid's Avatar
I've heard both yes and no. So, to be honest, I'm not sure.
But, you could get the tank, put in a new proper TPI pump while it's on the floor, and install it. A new pump while you're at it would probably be best way to go, anyway.
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
