HELP!!! 87 to 88 V8 swap
Old May 14, 2004 | 09:45 AM
Damageincta's Avatar
Car: GTA
Transmission: 700 R4
87 GTA engine , 88 GTA body and harness. i need to know the differences between(not sure of many) do i need the 87 cpu or can i use the 88?? any help would be great.a wiring diagram would be nice.. thanks guys
Old May 14, 2004 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I won't try to pass myself off as someone who has BTDT, but there shouldn't be a lick of difference.
Old May 14, 2004 | 01:36 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Gonna have to agree here, if it were 86 to 87 may be different because the birds switched to vss but I believe the 87 to 88 would be exactly the same.
Old May 14, 2004 | 04:22 PM
Car: GTA
only two things so far, alternator and ac compressor are on opposite sides and fan relays are different(oval instaead of square). so it just makes me wonder if there isnt anything deeper than that
Old May 14, 2004 | 04:27 PM
pasky's Avatar
Just move the accessories, all the mounting holes should still be there, I don't think the relay shape matters, if you feel you need to change them go to autozone, can buy them there cheap.
Old May 14, 2004 | 05:14 PM
five7kid's Avatar
Okay, how much of what's under the hood are you calling the "engine"?
Old May 15, 2004 | 02:00 PM
Car: GTA
ok heres the back story, i demolished my 87 GTA, got hit by a semi , i saved engine ,tranny. bought a 88 GTA minus engine and tranny, perfect for my needs, interior is in great shape , paint is rough, but all i need is to put my setup in that car..just wondering if theres any hints you guys can give me on doing this, i have never done this before..i was going to put the engine and tranny in at the same time, with a self leveling engine lift.
Old May 15, 2004 | 02:25 PM
pasky's Avatar
motor mounts are the same throughout the years, so the engine and tranny will be in the same spot. Same with driveshaft.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
