400 Cam Selection
Old May 16, 2004 | 12:34 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
400 Cam Selection
I'm looking at using the Comp 280AR(magnum) 280in/280exh adv 236in/236exh@.050 .550/.550lift 110LSA or the XR274R(xtreme energy) 274in/280exh adv 236in/242exh@.050 .564/.570lift 110LSA. Heads are AFR195's. Intake will be a HSR with the 730 ecm fueling it. What idle characteristics will these cams have. Also posted in the TPI section.
Old May 16, 2004 | 08:54 AM
ljnowell's Avatar
If you are wanting to use TPI forget both of those cams.
Old May 17, 2004 | 11:51 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
The guy helping me tune my TPI told me cams with 110 LSA or less are very difficult to burn chips for.
Old May 17, 2004 | 01:57 PM
eric305TPI's Avatar
I'm not going to be using the TPI but going to the Holley stealth ram intake with a 730 map ecm running it (possibly an open loop chip)
Old May 17, 2004 | 05:08 PM
lokoRS's Avatar
Car: 89RS
I would go for the second one, i like the agressive ramps. Is it a solid roller?
Old May 17, 2004 | 07:32 PM
eric305TPI's Avatar
Yep solid roller
Old May 17, 2004 | 09:43 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Solid might not be a good idea... they dont get along with knock sensors well.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
