350 build
Old May 19, 2004 | 02:16 PM
IANTI's Avatar
Car: 88' IROC
Transmission: 5 speed
350 build
currently i am in the proccess of purchasing a 350 sbc and am going to rebuild it. I was wondering if you guys could guide me with your knowledge as to what year block i should look for and what kind of components to build it to obtain anywhere from 375- 400 horse?
Old May 19, 2004 | 03:19 PM
ede's Avatar
ede
i'd look for a roller cam one piece main seal block.
Old May 20, 2004 | 01:59 PM
IANTI's Avatar
Car: 88' IROC
allright is there any other useful info out there?
Old May 20, 2004 | 02:23 PM
kevinc's Avatar
Car: 1982 Z28
Federal Mogul makes a good hypereutectic flat-top 2 valve relief piston that should work well for what you're doing, and doesn't cost much. H631P was the one I used, 0.030" oversize. If you want forged, JE and SRP are good choices for flat-tops.
I had the stock rods reconditioned, and added ARP rod bolts for some extra strength. Wasn't planning on revving past 6K rpm.
As ede mentioned, a later model block is favorable. The roller cam provisions are nice and you'll want a roller to make the kind of hp you're after. The 1-piece rear main seal is less prone to leakage than the older 2-piece design.
After that, you need to dig into cam, heads, and induction system (carb, TPI, aftermarket...) options. They're interdependent. These are dictated by your streetability and emission compliance needs, which you didn't indicate.
Old May 20, 2004 | 02:43 PM
IANTI's Avatar
Car: 88' IROC
allright thanks sorry for my lack of information but i am probably going to just go with a carb for this summer and i'm going to be driving it for the whole summer so streetability is a factor.
Old May 20, 2004 | 03:26 PM
kevinc's Avatar
Car: 1982 Z28
The Holley 650 vacuum secondary is a good option, Barry Grant's "Demon" series of carbs also good.
A single-plane intake will generally make more HP but at higher revs than a dual-plane. Go get a copy of David Vizard's applicable books and start reading, you'll like what you find.
I'd almost think about a set of GM FastBurn heads, a Vortec-compatible intake manifold, and a fairly bumpy hydraulic roller cam like the Comp XE series. Thunder Racing has a great selection of Comp and other manufacturers' cams.
Hit the Vizard books and see where it takes you. His carbs & intake book is a definite read, and maybe his head book also.
Old May 21, 2004 | 02:39 PM
IANTI's Avatar
Car: 88' IROC
allright thanks man you know how long the books are?
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
