Found LT1 for $850
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Found LT1 for $850
Hey guys
I called the local shops and I found an LT1 motor with harness and computer for $850. I had to drive for 2 hours to find the town where it was at. The motor has been out of the car for about 4 months and it looked pretty dirty. I also had corrotion on the back of it. The guy said it had 75k miles on it and he guarantees it.
This is the casting number i pulled from the ledge of the block 10125327
I also got a speeding ticket 74 on a 55 and the seatbelt
does anyone know how much are the fines?
does anyone know how much are the fines? Joined: Mar 2000
Transmission: 4L80E/4L80E
What did it come out of?
You're also going to need a transmission (and bell housing if manual).
If true, that's better than the Caprice/Impala engines, and '95 was better than the earlier, I've heard.
I assume you're reading up on the stickies at the top of the forum. Both the LT1 and V6 -> V8 swap, because they both apply to you.
They used the same block casting from '92-up. That doesn't help any, and it doesn't tell you body type it came out of.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yep, 95 is considered the best year for a swap because it has the improved opti design, hardened push rods, sequential injector fire (unlike the batch fire that was existent in 93) and is OBDI. I saw go for it if they can give you some sort of warranty.
Aluminum = lighter weight, dissipates heat more quickly, not as much flow.
Iron = Heavier, flows better, retains heat.
Its a Ying Yang thing.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I was trying to establish which vehicles received which heads.
Aluminum in Vette only, or Vette & F-body?
Cast iron in Caprice/Impala only?
Or....?
Or....?
Car: '90 RS
Engine: 377 LSX
Or....?
Or....?
Iron in all B-body cars (impy's, caprice, roadmaster cars etc)
Not sure if there is any truth to this, but I have heard of people on camaroz28 having iron heads on thier 93 f-bodies from the factory.
moreyes,
Reason I was asking is, if this engine has iron heads, you've got reason to doubt what you're being told.
Not unheard of for a "Vette engine" to have actually come from a truck, you know...
Car: 85 TA
Engine: 305 tpi
Transmission: 700
moreyes,
moreyes,
I also looked the casting number and I got this
10125327...350...92-up...2 or 4...Gen.II LT-1, reverse flow cooling
The Caprice and Impala have a different casting number. 10168588...265...94-96...2...L99, Gen.II, 4.3 Liter V-8, Caprice, reverse flow cooling
My guess is that they are aluminum since he says they came out of a trans am.
magnet will let you tell instantly, and also those head casting numbers you pulled are for the L99 not LT1 for B-body's also a good thing to check, don't wanna be suckered into a baby LT1.
10125320...94-96...350..........Gen.II LT1, cast iron version, used
on "9C1" Police package, Impala SS,
Cadillac Fleetwood, Buick Roadmaster
12554290...94-96...350..........Gen.II, LT1, cast iron version, used
The Caprice, Impala, Roadmaster, Vette, Camaro, and Firebird all used the same 5.7l block.
The "baby LT1" was only used in the B-bodies.
The block casting # won't tell you whether cast iron or aluminum heads. I wouldn't trust the lack of corrosion to make the leap that they're aluminum (I'm not sure if the factory painted them, for one thing).
Put a magnet up to the head itself. It it is attracted, it's cast iron. If it isn't attracted, it's aluminum.
Or,
Pull a valve cover and check the casting number of the head (the block has a casting number, the heads each have a casting number, the intake has a casting number, etc., etc., etc.).
Or,
New2Chevy
Sep 28, 2015 12:35 AM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
rudolphschenker
Sep 4, 2015 02:41 AM
