motor mount Q?
Old Jun 9, 2004 | 10:37 PM
tornado's Avatar
Car: 1987 Z/28
motor mount Q?
this guy told me that theres motor mounts that are stiffer then stock ones not sure what they where but he said that the stifer the better because when u rev ur engine ull realy feal the power
Old Jun 9, 2004 | 11:32 PM
ljnowell's Avatar
hmmmm. I dont think that you would want to go through all the trouble of changing your mounts so that they are stiffer and you feel the power.
Old Jun 10, 2004 | 05:20 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
There are polyurethane and actual solid mounts both made to fit our cars, if you are changing engines, or just mounts its typically good to swap to a set of poly's, I doubt you want to run solids.
Old Jun 10, 2004 | 06:30 PM
tornado's Avatar
Car: 1987 Z/28
thanks!!
how much do u think the mounts cost for a 350 in a 87 maro?
Old Jun 10, 2004 | 08:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I believe the poly ones are about 35 bux a side, need 2 total, and require a little extra work to install.
Old Jun 11, 2004 | 12:27 AM
tornado's Avatar
Car: 1987 Z/28
thanks!!
all probaly gets soma later on this week
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
