305 Carb to a 350 Carb
Old Jun 17, 2004 | 12:46 AM
86TAtony's Avatar
Car: 1986 Trans Am
Engine: LG4 305
I did a search already because I know this is a very common swap, but I just had some questions that I couldn't find the answers to. If I find ANY 350 chevy block can I use just about everything from my 305?I can use my intake, carb (I rebuilt the carb about 3,000miles ago and sealed all the plugs that can leak.), distributor, my prom computer from the 305, and the starter? I would be getting aftermarket heads or decent ones and headers. If anyone could give me some feedback it would be appreciated.
-Tony
Old Jun 17, 2004 | 01:41 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
everything, but i'm not sure about the intake. depending on which year heads you have/buy you need an intake manifold to match. Here is a picture that should help. They made the switch(i believe) half way through '86.
Old Jun 17, 2004 | 09:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Like the caption said, the switch was made in the '87 model year.
It would be a rare '86 that had the new type, or a rare '87 that had the old type (Vettes excepted).
Old Jun 17, 2004 | 08:38 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
You can use as much of the 305 accessories as you want, like I did, I even used my starter. Replaced other things with new, but were for the 305 application.
The flywheel/flexplate will have to match what ever block you use.
1-piece or 2-piece rear main seal
The intake will be the biggie, as stated above, but I would like to suggest that you drop the CC carb, CC dist., and the computer, all together, and go "old school". But that's up to you.
Old Jun 17, 2004 | 10:42 PM
jjay940's Avatar
Car: 2007 ion
i have a '78 350 that the starter and oil pan didnt bolt up right. The starter and oilpan were from a '84 305
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
