good deal or not
Old Jun 30, 2004 | 04:16 PM
ryans's Avatar
Car: Trans Am, Grand Am GT, Vibe Gt
Engine: 5.0, 3.4, 1.8
Transmission: std, auto, std
good deal or not
I finally got a thirgen last week. It is a 85 Trans am ws6, it has a carbed 305 5spd. It only has 119000 miles and every thing works in it for $1400. The 305 is not much for power so my friend found this guy who sells motors. The motor is currently in a 1971 caprice it is a chevy 400 that runs and everything for $300 is it a go or no go. I know it will bolt up no problem. If I do get it I plan on getting a stroker kit for it to make it a 454 from Eagle. It should have between 400 and 600 horse depending on what other mods we do to it
Old Jun 30, 2004 | 04:41 PM
ljnowell's Avatar
I thought the 454 was based upon an aftermarket block? 400-600 is a pretty broad spectrum, but I am assuming you are planning an all-out build to get that kind of horsepower,.
Old Jun 30, 2004 | 05:50 PM
ryans's Avatar
Its a 400 engine that runs right now. We are going to buy a stroker kit that makes it a 454 or 455 I cant remember which. There wont be stock part in the motor
Old Jul 1, 2004 | 01:02 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
You might want to reconsider stroking a small block out to 454 ci.
Old Jul 1, 2004 | 02:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A '71 Caprice 400 will be a dog. It needs different heads and cam to make much more power than your LG4. Honest.
Stroking a factory 400 block borders on self-abuse. Keep the 3.75" crank, fit it with 5.7" rods and matching pistons, bored .030"-over if it needs it to clean up the cylinder walls. With proper heads, cam, induction, and exhaust, it will be all the power you'll need until you're willing to spend the same money you have on the engine in transmission, rear end, and suspension upgrades.
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ChevyZ71
Aug 13, 2015 07:30 AM
