How should my PCV routing look after swap?
Car: 87' Iroc
I have the passenger side PCV valve connected to the PCV port on the carb. Should the driver side cover be routed somewhere? Right now it's open to atmosphere....should it be connected to the somewhere?
Car: 87' Iroc
Okay, so my passenger size valve cover has the PCV valve which is hooked up to my carbs PCV port, and the driver side simply has a breather on it?
1992 Trans Am
May 10, 2023 07:19 PM
downsouthboy
Aug 29, 2015 11:29 AM
