Putting in 350 question Help!!
Old Jul 5, 2004 | 05:37 PM
87'z28gpse's Avatar
Car: 1987 Iroc
Okay, I bought my 87' z28 with a blown 305 in it. I ripped the 305 out and threw it in the scrap bin. I then bought a 69' 350 to put in. I am going to use a carb. My question is can I put a normal fan on (non electric) or do I have to use an electric fan. I would prefer to use a normal fan but this is my first 3rd gen and I don't know about the fans and stuff. Any help is greatly appreciated!!
Old Jul 5, 2004 | 05:50 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i used to have electric fan for my 2.8 but wen i swapped in my 350 i converted to the "non-electric " fan that goes on the water pump. You will get about 10-20 horsepower if you keep the electric fan i have heard. but im not sure if thats true or not. my electric fan didnt work wen i got my car anyways, so i kept it that way.:lala:
Old Jul 5, 2004 | 05:52 PM
kevinc's Avatar
Car: 1982 Z28
A mechanical fan will fit, my '82 originally had one when it was 305 CFI.
Old Jul 5, 2004 | 06:13 PM
87'z28gpse's Avatar
Car: 1987 Iroc
Will it fit under the stock hood??? (excuse my stupidity, I am new to the third gens)
Old Jul 5, 2004 | 06:39 PM
Drakar's Avatar
Mechanical or Clutch fans where standard on most LG4 cars, (carbed weak 305), it will fit under a camaro hood no problem ... not sure on Firebirds
Old Jul 5, 2004 | 08:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use the electric fan. It's better. Cools better, uses less power. You will gain nothing by downgrading it.
Old Jul 5, 2004 | 08:40 PM
87'z28gpse's Avatar
Car: 1987 Iroc
Okay, I will use the electric, since everybody says it is better I just wanted to know if I had the option to use a clutch fan. Thanks for all the help!!!!
Old Jul 5, 2004 | 09:40 PM
Drakar's Avatar
not that Im doubting you, but isn't a clutch fan better at cooling?
the LT1 I pulled from a wrecked Roadmaster had the HD Cooling package on it part of the towing package and it was a clutch style?
Im personally switching to dual fans as I am currently installing it in my 85, just wondering what's the deal thats all.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
