Take off Fuel Rails and injectors?
Old Jul 12, 2004 | 03:33 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Hey everyone,
I was in the process of breaking down my LT1.
I got everything off except for the fuel rails and injectors.
I removed the four bolts on top that hold them down, but they still won't come up. I slid the littel retainers back that hold the injectors in place on the fuel rail, but it still won't budge.
Do I need to oil them up so that they'll slide out?
Thanks!
Old Jul 12, 2004 | 04:54 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Get an open end wrench, 19MM or so, big enough that the open end will clear the OD of the base of the injector, but still a bit smaller than the body of the injector, slip it between the injector and intake, then pry up a little bit, they'll slip out.
Old Jul 12, 2004 | 05:04 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
The rail and injectors should come up together. You should even be able to grab each injector and give it a slight twist just enough to get them loosened. When reinstalling them, put a dab of petroleum jelly on the washers so they slide in easier and for coming out easier as well.
Old Jul 12, 2004 | 05:24 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Yeah, I heard of people using lube to get them in.
I just wanted to make sure if I pulled them out with no lube, I wouldn't ruin them.
Thanks for the help, I got them off.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
