350 swap in
Old Jul 13, 2004 | 07:04 AM
ph0nix86's Avatar
Car: 86 Firebird
Engine: none, it blew up
Transmission: 700R
350 swap in
Will a TBI 350 out of an 87 Suburban fit into my 86 firebird?
Old Jul 13, 2004 | 10:57 AM
ljnowell's Avatar
Yes. But remove any and everything that has to do with induction on that engine and change it. Get a new cam too.
Old Jul 13, 2004 | 04:55 PM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
what do u mean by induction, and will the pcm match up to the wiring harness?
Old Jul 13, 2004 | 05:21 PM
ljnowell's Avatar
You dont want anything to do with TBI. Do a and you will find out all about swirl port heads, TBI, and all the other problems that come with it.
Old Jul 13, 2004 | 05:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Now don't say that Although not always ideal TBI can provide nice power levels while maintaing good fuel economy and overall drivability when paired with the right parts. People just give up on it when the chip buring comes along. Plus if you max it out you can alsways convert to carb or another multi port set-up and hardly lose any of the parts you have already invested into your motor.
Old Jul 13, 2004 | 05:43 PM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
Im not concerned with power or performance right now. The cars been out of service for about 2 years now and I miss driving it. I'm still woundering if the wiring harness will plug into my pcm that was for a carbed engine or if i would have to get one for a TBI.
Old Jul 13, 2004 | 05:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Whether you go to TPI or TBI or any other FI system you are going to need a harness that is desinged for that set-up.
Old Jul 13, 2004 | 05:59 PM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
The engine in the suburban has a harness but i didnt know if it would make a diffence to put in the my firebird
Old Jul 13, 2004 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put the 350 long block only in your car. In other words, transfer the intake manifold and everything above it, alternator, water pump, power steering, air conditioner, distributor, harness, sensors, etc., from your current engine to the 350.
Old Jul 13, 2004 | 06:10 PM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
what if i dont have the stuff anymore
Old Jul 13, 2004 | 07:53 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Hit yourself LOL
As of right now, id get a Edelbrock rpm intake, and a good 750 cfm carb.
Later on, you could get vortec heads, and a xe 262, 268 or 274 camshaft.
Old Jul 13, 2004 | 08:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What do you have and what don't you.
Old Jul 13, 2004 | 08:59 PM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
i have the PCM, the hacked up wiring harness, rusted out carb and intake, and i have headers. pretty much all the vaccume and emissions stuff is gone
Old Jul 13, 2004 | 09:13 PM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
if i used the engine out of the suburban and got a wiring harness and an ecm for a third gen would the harness work on the suburban engine?
Old Jul 13, 2004 | 09:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
For the most part. However, there are IAC differences between the truck TBI's and car TBI's. Not all of them but most of the older ones are different. You will need to do some splicing.
Old Jul 14, 2004 | 06:49 AM
ph0nix86's Avatar
Car: 86 Firebird
Transmission: 700R
Alright i think i cant handle that. thanx for your help
Old Jul 14, 2004 | 02:53 PM
five7kid's Avatar
It would have been nice to know the state of your car up front.
At any rate...
If you don't have emissions inspection/testing, the simpliest way to get it on the road will be with a non-computer controlled distributor and carb. You'll need a different intake manifold as well: Weiand makes one that will bolt up to those heads ('87-up; but it doesn't have EGR valve provision - however, I'm assuming for the sake of this arguement that won't be an issue). Since your car originally had a carb in it to begin with, this route will be much, much simplier than trying to get all the harness/computer/sensors/pieces to make the TBI work that it just happens to have on it right now.
Old Jul 14, 2004 | 05:00 PM
Drakar's Avatar
If EGR is needed Weiand 300-64 has egr and is for 87+
Old Jul 14, 2004 | 07:43 PM
five7kid's Avatar
That's a Holley number (Holley owns Weiand, I know), with square-bore carb mount only. Summit p/n HLY-300-64.
The manifold I was thinking of is the 8024. Summit p/n WND-8024.
Why they offer a square-bore mount w/EGR manifold (the Holley), but non-EGR only w/spread-bore mount (the Weiand) for the '87-up configuration is beyond me.
Old Jul 14, 2004 | 08:57 PM
Drakar's Avatar
Corporate Wisdom I guess
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
