350
Old Jul 13, 2004 | 09:12 PM
ph0nix86's Avatar
Car: 86 Firebird
Engine: none, it blew up
Transmission: 700R
350
If i used the engine out of the suburban and then got a wiring harness and ecm for a third gen would the harness work on the suburban engine?
Old Jul 13, 2004 | 11:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Refer to here.
Old Jul 14, 2004 | 01:08 AM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
assuming 350 engine..yes.its not the engine that makes the harness work its the induction system and sensors its with. so the induction off the third gen that the harness came with . thats the easiest way.
the easiest way to go. go to a j yard get a stock q jet off a camaro or bird and the harness thats with it , freshen it up. thow it on.. or
edel performer intake off ebay or so roughly 75$
and a edel 1406 off ebay 100-150$
stock dist ..do you have one?
throw it on run a hot wire switched to your coil and gas to your carb your suburban engine and your good.
all depends do you need it emission freindly?
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
