converting to tpi on a 83 cutlass
Old Jul 19, 2004 | 01:50 AM
sassyherbbassi's Avatar
Car: 93 Firebird Formula/79 Trans Am clone
Engine: LT1/LT1
Transmission: T56/4L60E
the car is a 83 olds cutlass.
its a sbc 305, im gonna get a tpi setup off of a third gen f body.
my main concern is the bracketry, can i use the stock ones on there now? any other suggestions or anything i should remember before doing the swap?
i was planning on just swapping the top end: intake, fuel rail, injectors, harness, pcm, heads, and hydrualic cam, lifters, pushrods.
will this be a bolt on?
can i use the th350 tranny thats in there?
thanks
Old Jul 19, 2004 | 05:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '83 Cutlass engine is basically the same thing as an '83 3rd gen engine. A search will yield all the info you need.
You'd have to be asking about putting the '83 Cutlass engine into a 3rd gen in order to comply with board rules, so....
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
