swapped 3.1 to 350 carb 91 rs
Old Jul 22, 2004 | 08:33 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
i did the swap and everything seemed to be fine until it died from lack of fuel i can see this in the glass. i turn the key on it fills up and i can start it and go for a mile then it dies. i ran the fuel line directly to the fuel pump on the block, same thing, ieven had um both working ,the same crap, whats up fellas
Old Jul 22, 2004 | 11:24 PM
ljnowell's Avatar
if you have a fuel pump on the block, did you remove the one from the tank?
Old Jul 23, 2004 | 07:51 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally posted by dmp7777777
i turn the key on it fills up and i can start it ...
Sounds to me like the electric is still in there.
You need to use an oil pressure switch to keep the electric running after the engine starts. What's happening is the timed relay is allowing the pump to start when you turn on the ignition, but as designed it shuts off a few seconds later. The mechanical on the engine isn't able to suck hard enough through the non-running electric and keep up.
You should also have a regulator in there (after the mechanical would be fine), the type of reg that uses a return line. The electric will be the "pusher", and the mechanical the final pressure up to the carb.
Old Jul 23, 2004 | 10:58 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Re: Re: swapped 3.1 to 350 carb 91 rs
When we put my motor in i wired the fuel pump to the ops on the v8. Never had a problem with the fuel pump.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
