2nd new engine in 2 months....im done
Old Jul 17, 2004 | 10:24 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
the first engine put in my 86 z28 was a new 305 i had everything replaced from the radiator to the transmission and i mean everything....any the rings washed out to bad reman...carborator......now just paid again for the second engine and it boils over every time u drive it and turn it off....everything is new and i have put over 5000 dollars in a car that is no better now then it was origanlly...here is the question try and fix it or give up cause i am out of money and am really pissed.....thanks for the advice.......
Old Jul 17, 2004 | 11:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like an air bubble in the 2nd engine.... pop out the thermostat and fill the engine through that, then put the thermostat back in, seal it all up and try it again
Old Jul 17, 2004 | 11:37 PM
TexasLT1's Avatar
Car: '92 RS
if that doesnt work, get the radiator rodded out or get a new one.
*edit* nevermind, just saw where you said everything was new, so I have to assume the radiator is too
Old Jul 17, 2004 | 11:45 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
radiator is new...i replaced the thermestat today and when i took it off the engine was full of coolent in fact made a mess coming out of where thermestat was. the engine has about 200 miles on it...if u just let it idle it will go to 250-260 is that right?
ive heard new engines run hotter but for how long? any advice help me keep my third gen....thanks
Old Jul 18, 2004 | 06:35 AM
contactpatch's Avatar
Engine: sbc 350
take the t-stat OUT,
(not needed in the summer)
and tell us what happens.
Old Jul 18, 2004 | 09:38 AM
TexasLT1's Avatar
Car: '92 RS
Do NOT do that, or it will heat up and boil over even faster. Ask how I know. You NEED the thermostat in there. If not, the coolant in essence does not stay in the radiator long enough to transfer much heat to the ambient air. You need the thermostat as a restriction in the coolant system in order to get proper cooling.
Old Jul 18, 2004 | 09:39 AM
TexasLT1's Avatar
Car: '92 RS
what fan(s) do you have?
Old Jul 18, 2004 | 11:08 AM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
brand new 16" perma cool 2900 cfm electric fan
Old Jul 18, 2004 | 12:49 PM
ljnowell's Avatar
I ran a car without one for 3 weeks one time, and it never overheated.
Old Jul 18, 2004 | 05:06 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
heres what ive done
today i replaced the 195 therm with a 180 and wired a manual switch to the fan so i can turn it on before 240 and seems to hold it at 200-210. by the way its 104 degeees here in so cal. does that sound ok ......thanks
Old Jul 18, 2004 | 05:53 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
JET and Hypertech both sell fan switches that turn on at either 160 or 180. Mine worked perfect until I burned the wire up with my new headers.
Old Jul 18, 2004 | 10:33 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
What is the timing set to? Is the car running lean at all?
I know you said everything was new, does that include the water pump too?
Old Jul 18, 2004 | 11:14 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
havent checked timing yet what should it be set to any ideas thanks. not running lean
Old Jul 19, 2004 | 12:24 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
There should be the emissions label either on the hood or the upper fan shroud plate. Mine is an 89 305TBI, swapped to an 87 350 TBI. Factory setting is 0º, but I keep mine at like 6º BTDC.
Old Jul 19, 2004 | 12:34 PM
TexasLT1's Avatar
Car: '92 RS
And how hot was it outside? I ran my car without it for a week in south Texas and I barely made it to the shop everytime because it heated up so fast.
Old Jul 19, 2004 | 12:36 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
on the overheating part:
check timing.
make sure you arnt running lean.
double check timing.
#1 cause of mystery overheating that everyone over looks: timing.
Old Jul 19, 2004 | 08:19 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
less anti freeze and more water will help cooling.. as will water wetter.. but system should handle a 50/50 mix and no water wetter and work fine. as for t-stat.. I ran mine without one for a couple weeks... but the weather here is quite a bit cooler.. all i can say is try it.
i programmed my computer to turn fans on at 95C .. think thats about 185-190F .. but you can get the fan switches that will do that for you. look for the total fan control article on here.. as for why its heating up.. check timing. since thats easy.. then make sure water pump is up to par even if it is new..
Old Jul 19, 2004 | 09:04 PM
ljnowell's Avatar
I live in illinois, and it was summer. So anywhere from 80-99 degrees usually around low 90's. Course this wasnt with one of the crappy stock radiators in our cars, this was in a 78 olds cutlass with a heavy duty big *** radiator. Might have made a difference.
Old Jul 19, 2004 | 10:03 PM
TexasLT1's Avatar
Car: '92 RS
definitely was the key, I have a stock replacement rad. with a single fan at the time. Guess you just got lucky, most of the time no thermostat results in overheating in record time.
Old Jul 19, 2004 | 11:53 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I have taken the thermostat and cut the middle out (spring and stuff) and stuck that in.
Works wonders on overheating problems, better than anything I have ever used.
Old Jul 20, 2004 | 12:14 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Not trying to be funny but are you sure the fans are rotating correctly(right direction). I had a friend that wired his to push and didn't even realize it.
Old Jul 20, 2004 | 08:58 AM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
when i put my hand between the fan an engine i can feel it blowing air over the engine therefore sucking air through radiator right?
Old Jul 20, 2004 | 09:07 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
mine runs 210 on the head and about 200 on the block year round and i havent had a problem (yet) good luck ... tao
Old Jul 20, 2004 | 11:08 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Sounds right....since you installed the switch, turn it on and off right away, watch which direction it goes as it stops. That should tell ya.
Old Jul 20, 2004 | 12:18 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
check timing.
ibwats,
I forgot to mention that you need to unplug the advance wire to check the timing. It should be a tan wire with a black stripe, right behind your pass strut mount. It comes out of the harness loom for a few inches and then goes right back in. There is a weather pack quick connector there.
Wait a minute, let me see if I can show you what I am talking about...
Oh yeah, if you already know this, my apologies.
Old Jul 23, 2004 | 02:44 PM
LT1guy's Avatar
Car: 1987 Trans Am
Re: heres what ive done
Thats pretty good considering the temperature. You might even want to wire the fan to come on immediately, with the igniton (just wire it to an ignition-hot source). The only real downside might be a slightly reduced fan life, but I have run several electric fans that way with no ill effects. Do you have AC, and what does it do to the temp when its on?
Old Jul 23, 2004 | 03:09 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
when i turn on the ac on a hot day it runs 225-230 in traffic maybe 240. i still am running that break in oil so i dont know if that makes it run hotter
Old Jul 23, 2004 | 03:43 PM
LT1guy's Avatar
Car: 1987 Trans Am
The oil shouldn't make any difference. A few things to check:
1) is the air deflector/air dam under the car in place and in good shape? If not, replace/repair it. You can also extend them a couple inches to pick up more air.
2) Is your aftermarket fan properly shrouded, and large enough to cover most of the radiator core? If not, that could be part of the problem.
3) Its been mentioned before; timing. Retarded timing can cause overheating.
I'd put a 160 thermostat in, at least for the summer, and make sure you have at least 50% water in the radiator. Straight coolant, or higher percentages can cause it to run hotter. You might also add some Redline Water Wetter or Royal Purple Purple Ice. Turning the fan on sooner should help also.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
dhonda200
Aug 11, 2015 11:50 PM
