400 block??
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
400 block??
i can get one, what to do with it, 350 heads, aftermarket, i want 500 horse from it,
help me....
help me....
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
500 horse on pump gas?
Aftermarket +190cc heads, solid or roller cam, +230 duration/+0.500lift cam, 1 3/4" headers, +10:1 compression are yer basic minimums.
Best thing about 400's really is the torque. Spend at least $800 on a good set of heads and yer basically guaranteed +400hp/400lb-ft(1500-5000) with something like an XE274 camshaft which is a great street/strip cam. Very Idle friendly in a 400.
If I was making a motor for what I thought would be guaranteed 500hp I'd go with 210cc AFR, Canfield, Pro Topline, Brodix or Dart heads(CNC'd aluminum heads for sure to make it street friendly), 10.5:1 compression, rpm air gap or super victor intake, 1 3/4 headers and either hyd roller cam with 240-250 duration and about 0.550 lift(really this would depend on the intake) or a solid grind with about the same specs... really depends on alot of variables for the cam.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
500hp is a pretty lofty goal. You will need awesome heads ie AFR 210's. A big solid roller cam ie XR280 or XR286. You will also need a bullet-proof bottom end, read forged everything.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Ready sig....
Then take about 7 grand out of the bank!!!!
P>S Not street friendly!
Then take about 7 grand out of the bank!!!!P>S Not street friendly!
Car: 87 IROC Z28
Thanx guys, i think i just might build that one, but for now, i thik ill drop a 454 that i just found...its already makin over 500/500...hmm.....nice...
I donno, maybe ill change my mind, keep em commin
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
84 TA NV
Sep 6, 2015 08:02 PM
