what do you think about my future 305 tpi setup
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
this is what i have lined up for my lil'305
stock 97 lt1 cam, fully ported 081 castings with a 3 angle valve job, stock ported base and port matched, portmatched stock runners, ported plenum, stock tb
what you guys think?
what kind of power you think it will make?
sould be a a pretty nice sleeper since when you look under the hood its a stock 305
thanks
thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It looks really good but I would look into some chip work along with at least a better base and runners. You are going to kill your top end even with "worked over" stock TPI parts.
i figured that much but i will run it on the stock chip for now and it should run desent until i ahve the time to program my own or money for an ed wright chip
as for the tpi parts it would only be for now
i want to do this as low buck as i can
i will see if i can get some used pieces for the boards and ebay
but with the stock tpi stuff it will be quite torqy
Sanjay
Aug 12, 2015 03:41 PM
