tpi, carb, or tbi?
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
tpi, carb, or tbi?
ok ive been wrestling wth wht induction to use on my 383. i knw the trak records of the carb and tpi but in the long run which is better? keep in mind ths is goin to be a streeet car wth regular tags
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: tpi, carb, or tbi?
Transmission: 4L80E/4L80E
Least work, probably keeping TBI - assuming you assume PROM tuning, replacing intake w/something better, and 454 TB.
Least expense would probably be carb.
Best mix of performance, fuel economy, and driveability would probably be a TPI-based system with LT1 or Miniram intake. Again, PROM tuning must be assumed.
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
TPI will give you better fuel economy/emissions and still make very good power if you use the right kind of intake stealthram/miniram/superram
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
guys ive finally reached a decission, after a lot of thought and jegs searching, im gonna go wth efi. the thing is its not ur traditional efi: i was looking through jegs and found a tbi/efi conversion....y not use wht u hve..right.. its a kit made by edelbrock, and its reasonable on the price side too. originally its ment for trucks so it should make an already torq-e 383 more so. lemme knw wht u guys think. constructive critasism welcomed. Trending Topics
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You could always get the LT1 intake that has been converted for use with a distributor instead of a TPI intake so you can get the shorter runners.
I think this is pretty cool, but if have more than 435 hp potential, its not the greatest for you: http://www.edelbrock.com/automotive/mpfi_sbchevy.html
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
the one im thinkin of isnt the regular mpfi, here the part number from edelbrock..#3502, besides i could always do heavier injectors, holley throttlebody, etc.. Thread
evilstuie
Jan 9, 2020 08:29 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
