454 swap (frame ?s)
Old Aug 2, 2004 | 05:33 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
Transmission: Turbo 400
454 swap (frame ?s)
Ok this winter im gonna swap a 454 in my camaro. Its a 85 iroc. Im gonna be useing a built 10 bolt rear and a turbo 400 trans. The motor is gonna be mild stock internals with ported heads, big cam, lifters, pushrods, rocker arms all that good stuff. Will a roll cage be needed to keep the body from twisting from the torque?
A few ppl have been telling me i should but i though i would ask you guys.
Jeremy
Old Aug 2, 2004 | 05:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will need a cage if you plan on running your car down the strip more than once. By the numbers I asume you are going for, without every safety thing on that car you won't be able to run many places.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
