New Engine
Old Aug 8, 2004 | 10:26 AM
VIPER52USA's Avatar
Car: 1991 Camaro RS
Transmission: Automatic
New Engine
WASSUP GUYS. I'M KIND OF TIARD OF PULLING UP TO A LIGHT AND BEING DUSTED BY THESE NEWER CARS OUT THERE. SO, I HAVE DECIDED THAT I WANT TO DROP THIS IN MY 1991 CAMARO RS.
http://www.jegs.com/cgi-bin/ncommerc...28&prmenbr=361
ANYWAY, YOU GUYS KNOW MORE THAT ME. WHEN YOU PUT A NEW ENGINE IN A CAR WHAT ELSE DO YOU NEED TO DO/CHANGE/ADD TO THE CAR?
P.S. CANT GET THE CAPS OFF... DONT ASK
Old Aug 8, 2004 | 11:56 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
The Search button is your friend my man. There's load of info out there about these kinda swaps. I'll share some quick info tho.
If the 350's a carb, there's not much wiring to do, execpt take your old wiring out. Is your car a 5-speed or auto? Either way, just put your old flexplate/flywheel on the new engine, and hook up the fuel lines, and go. There's more, just do a search. Good luck!
Old Aug 8, 2004 | 12:10 PM
VIPER52USA's Avatar
Car: 1991 Camaro RS
NOPE, IT'S AUTO. I WAS JUST THINKING THAT I WOULD PROBABLY HAVE TO CHANGE THE TRANNY OUT AND THE TORQUE CONVERTER. I'LL LOOK AROUND.
Old Aug 8, 2004 | 09:03 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
The 700R4 you have now could probably take the power stock, but a good rebuild and higher torque converter should be in the plans down the road.
Old Aug 11, 2004 | 05:54 PM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
.....What kind of et's can he expect with that crate motor?.....Zapr.
Old Aug 11, 2004 | 06:01 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
make sure you check stock from Jegs and dont call them, their reps can not spell. I had to go pick my motor up from the terminal (Yellow Freight) because they got the wrong phone, address and name on the order! 3 days of hassle, maybe check Summit and SDPC too.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
