Left side oil dip stick problem
Old Aug 22, 2004 | 05:57 AM
Chopper_86's Avatar
Car: '82 Trans Am; '85 Camaro
Engine: 350 cid; 2.5 mini 6
Transmission: TH 350
Axle/Gears: Posi Richmond 3.73
I just swapped out the LG4 engine from '82 T/A with a genI 350 short block with the oil dipstick on the left side. I want to use the stock exhaust ( due to emission laws ) but the manifold won't clear the dipstick. The down pipe (where it bolts to the Y pipe is right by the hole. Any advice or suggestions would be greatly appreciated.
Thanks...Tom
Old Aug 22, 2004 | 02:41 PM
yugi-master's Avatar
Car: 1987 Trans-Am
Engine: LG4
been there
I just dropped a 010 350 in my 87 t/a and had the same problem, BEST thing you can do for the performance is get headers....
now with that said, i didnt have the cash for headers yet so i had to modify mine, if you use a regular dipstick made for the lefthand side, you can use a tubing bender and alot of patience and bend it up to where it passes between the head and manifold, tis a tight fit and we had to lightly grind the manifold and head to smooth out the castings but the dipstick goes through there fine, has zero hangups in the tube and measures correct. downside is the oil tube is resting on manifold and will get hot.
do this with valve cover off on that side as the lip on the valve cover will clear fine when done, but is in the way while working.
Old Aug 22, 2004 | 06:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Emissions-legal headers are available. Or, a Lokar flexible dipstick has been known to work.
Old Aug 22, 2004 | 07:57 PM
Chopper_86's Avatar
Thanks for the advice as both are helpful. I was not aware that they made a flexable dipstick. I'll have to look into that option......And glad to be aboard!
Thanks...Tom
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
Fronzizzle
Aug 9, 2015 01:15 PM
