Which fuel lines to upgrade?
Old Aug 23, 2004 | 02:37 PM
75/92 Birdman's Avatar
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
I swapped in a 350 TPI in place of the 305 TBI and I am told I need to upgrade the fuel lines to bigger ones to get more fuel to the motor. Which ones do I need? Can I just upgrade the main line and leave the return and vacuum the same size? I need to know so I can order them and get the damn car very streetable.
Old Aug 23, 2004 | 04:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to upgrade the in-tank electric fuel pump, not the fuel lines.
Old Aug 23, 2004 | 08:17 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
the lines are fine you need to upgrade your fuel pump like five7kid said
Old Aug 24, 2004 | 06:34 AM
We already did that, upgraded to the TPI fuel pump. The guy who tuned the car and is familiar with this stuff said you had to upgrade the fuel lines as well. The car runs and drives fine, but can't get the fuel it needs at startup.
Old Aug 24, 2004 | 08:35 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Get a new mechanic. What is the problem if it runs and drives fine? What makes him/you say you aren't getting enough fuel at startup?
Old Aug 24, 2004 | 11:53 AM
Well, the car won't start. We spray a little starter fluid in there and it fires up and drives fine, it is just the initial startup.
The car is also only getting 26lbs of fuel pressure, when we put the 75lb pump in there. Will a fuel pressure regulator help? Maybe an external fuel pump? I really don't want to drop the damn tank again.
Old Aug 24, 2004 | 01:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I thought TPI needed around 45 psi fuel pressure? Maybe you just got a bad pump?
Old Aug 24, 2004 | 05:56 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I would do the fuel pressure regulator first. If that doesn't help, you may have a bad pump. Are you using the factory wiring for the pump or did you rewire it yourself?
Old Aug 24, 2004 | 05:59 PM
JesasaurusRex's Avatar
Shouldnt have got another intank pump (if u plan on keeping the car) w00psys, maybe next time huh. But ya the lines r fine.
Old Aug 25, 2004 | 06:17 AM
k, I'll try a regulator and see if that helps.
If it doesn't, can I run an external pump withouth having to remove the in-tank one?
Old Aug 26, 2004 | 10:29 AM
Nope you cant lol, I already thought of that and it dont work my friend. Sorry time 2 drop the tank tho.
Old Aug 26, 2004 | 06:28 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
You CAN run an external pump with the in-tank pump, as long as the in-tank pump doesn't flat-out die. If it's producing low pressure but still has plenty of volume, that's all the booster pump will need. Ford used this system for years on their full-size vans and some trucks (volume pump in tank and "booster" pressure pump on the frame rail.)
However, if the in-tank pump quits working altogether, the booster pump won't pull through it.
Old Sep 1, 2004 | 04:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Normally a TPI car runs at 45 psi because that's what the fuel pressure regulator is made to do. The fuel travels through a loop from the fuel tank and back to the fuel tank again. Some of it is used by the engine but most of it goes right back to the fuel tank again. If you could close down fuel flow (send less back to the fuel tank) it would raise fuel pressure to 80psi or more. If you just let fuel go back to the fuel tank unrestricted then the fuel pressure will drop significantly below 45 psi (perhaps 26 psi??? ). The key to solving your problem is to install a fuel pressure regulator that can regulate the fuel pressure to the proper level for your TBI system, which is way below the 45 psi needed for a TPI system. Basically, you installed a higher flow pump. You need the right regulator to control everything.
It's like a water hose. You can let it run wide open under low pressure or you can stick your finger on the end and let it run under high pressure. Your finger is the pressure regulator.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
