MGB with a v6
Old Sep 8, 2004 | 09:22 PM
adam90009's Avatar
Car: 1979 MGB
Engine: 2.8 MPFI
MGB with a v6
I'm putting a 2.8 V6 form an 86 Camaro in my 79 MGB and I need some help. I have everything but the O2 sensor wired up and one wire from the coil that I don't know where it needs to go. Its the black and white wire from the gray plug. When I try to crank it the engine turns over fine but the engine will not start. Once the engine fired on about 3 cylinders but that was it. I checked the diagnostics on the computer and it kept flashing the 12 code and that was it. Any thoughts at all? and to see pics go to my webpage: http://bellsouthpwp.net/a/d/adam90009/v6_conversion.htm
Thanks - Adam Housley
edit: By the way this is my first engine swap and I'm 16.
Old Sep 9, 2004 | 12:52 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Congrats on the swap
Any pics of the black & white wire w/the grey connector? And which coil wire????
Old Sep 9, 2004 | 05:01 PM
adam90009's Avatar
Car: 1979 MGB
Engine: 2.8 MPFI
here are two pictures, It is from the light colored lug on th top of the coil and the 2nd one shows what the conector looks like.
http://bellsouthpwp.net/a/d/adam90009/IMG_4365.JPG
http://bellsouthpwp.net/a/d/adam90009/IMG_4367.JPG
Old Sep 9, 2004 | 05:44 PM
Engine: 5.7 / 7.4
it looks like the ESTC connector, but I no longer have it on what's left of the 2.8 harness.
MagnumRT05
Feb 27, 2009 10:09 AM
tmkhum
Oct 25, 2007 08:47 PM
Firm
25
Feb 17, 2007 09:00 AM
StreetRoc85 350
Jun 28, 2006 12:53 AM
83ZMan
Mar 6, 2002 06:24 PM
