how to get the underdrive pulley off
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I see no pulley.... you talking about the balancer? You can rent a tool to pull it off...
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i know, i had one i stripped the center out of it. its a underdrive pulley/balancer. its on there for life i think.
ya to take the crank pulley off you remove the three very visible bolts, then you have a small hub on, which you remove by removing the center bolt, which looks gone already.
then you can pull the crank from underneath or remove the opti if thats what your doing
well i finaly got that stuborn s.o.b off. i figured getting the crank pulley off the hub was usless. so i tryed to pull the balancer with it. after about an hour i got it.
. i actualy put another washer on the center bolt and tightened it in more then i put the puller back on it and it came right off. thanks for the help guys.
. i actualy put another washer on the center bolt and tightened it in more then i put the puller back on it and it came right off. thanks for the help guys. Thread
bigjay89gta
Oct 15, 2015 08:04 AM
