donor car
Old Oct 9, 2004 | 06:51 PM
UDAMON's Avatar
Car: Mazda Protege5
donor car
ok so im looking for a donor car for a v8 swap. i know its good to get your same car as the donor but how far can you vary from your model? like using a firebird donor for your camaro? or differences in generations? or completly different cars all together? would all the same parts still be there to use just as easily?
Old Oct 9, 2004 | 11:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
An engine, is an engine, is an engine. It doesn't really matter what vehicle it came from, all SBC's are about the same. If your going to do a total swap you can use any engine from any 3rd gen. But any SBC will physically fit and work. If it was me i'd get any 350 or 400 and put on a carb, or an LS1!
The parts from any 3rd gen 82-92 Camaro or Firebird will work for parts. It doesn't really matter others will work too.
Old Oct 11, 2004 | 02:33 PM
UDAMON's Avatar
Car: Mazda Protege5
hey cool thanks.
Old Oct 11, 2004 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, the tach will be different in a 'Bird than in a Camaro. And, that's one thing that needs to be changed in a V6 to V8 swap.
You should also look for '91 or '92, since yours is a '91. But, that's primarily for emissions legality.
Having put a complete '86 LG4 into an '82 V6 body, I can tell you that you will come up against "little things" if you deviate too much. Little things like the ECM harness pass-through plug being larger for the '86 than in the '82. And, I did a complete dash swap, only to discover the rear chassis connector (and number of wires) changed between the years. Spent a lot of time sorting that out.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
