AC/Alt in way of Steering of 3rd Gen LS1! Help!
Old Dec 8, 2004 | 10:49 PM
  #51
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Well the would have to be specially made and welded right and it probably wouldnt be all that strong. Im not sure who I would have make them and it would be just more of a hastle because Then I would have to take the right header off again, I would have to rent the cherry picker for the 30th time and it would probably be more of a pain in the ***. If I would have had the motor out then that might have been a option to look down. Good idea otherwise though.
Old Dec 9, 2004 | 01:21 PM
  #52
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Have you considered gonig back to the factory k-member? The spohn mounts for the factory k-member do not have any issues whatsoever.
Old Dec 9, 2004 | 03:27 PM
  #53
If I still had the old one, I might have considered it because I do have the conversion mounts because I bought the motor mounts and trans crossmember from fbody motor sports. I know I could get another one, but right now I want to get this project done with out have to unbolt that motor again. Not only that but I dont want to take steps back like going back to stock kmember and using stock steering when I can upgrade for with less work even if its more money because Im trying to do everything right. From what I hear the Rack and Pinon will be loads better than the Pitman and Idler arm setup.
Old Dec 9, 2004 | 09:07 PM
  #54
wm_sorg's Avatar
If I am not mistaken there is a rack and pinion kit that works in conjuction with the stock k-member. Make sure you check you driveline angles once you get the steering situation resolved.
Frozer!!!
Jan 19, 2024 04:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
