headers for an lt1
Subscribe
Nov 10, 2004 | 09:59 PM
how much difference is it realy goin to make hp wise in a lt1 using 1 5/8 rather than 1 3/4?
Reply 0
Nov 10, 2004 | 11:46 PM
Stock LT1, probably not much difference.
Reply 0
Nov 10, 2004 | 11:55 PM
forgot to mention its the motor in my sig. i want to get into 11's with nitrous but i want to run 12s without and im thinking of how much a loss the 1 5/8 is gonna be compared to a 1 3/4.
Reply 0
Nov 11, 2004 | 07:56 AM
I'm running Hedman 1-5/8" headers and I'm at 12.8 @ 110 with almost a full LT4 conversion with Hotcam. 1-5/8" will be fine, but you'll still make more with 1-3/4".
Reply 0
Nov 11, 2004 | 06:09 PM
Just to give you an idea; almost every set of headers made for LT1 4th's come with 1 3/4" primaries.
Reply 0
Nov 11, 2004 | 10:55 PM
how bout a 1 5/8th and a cutout... or is the damage done already after the headers???
Reply 0
Nov 11, 2004 | 11:18 PM
cutout definitely helps, but the only way you're going to get all the power out of it is with 1-3/4" primaries.
Reply 0
Nov 12, 2004 | 07:19 AM
with that 306 youd be foolish to go with anything other then the 1 3/4..also remember that the exhaust port for LT1/4 heads are d-ports...not the traditional oval port as in SBC's
Reply 0
Nov 12, 2004 | 08:27 PM
ok ill will probraly go with a 1 3/4. any recomendations?? long tube or shortys?? brands that are good but below 500$ i found a nice set of slp shortys but they sure arent cheap. if i could get away with a set of long tubes i would rather do that but i realy dont like the idea of them hanging so low and i have yet to find a set.
Reply 0
Nov 12, 2004 | 11:04 PM
forgot to add i need them emmision legal. i meant to say i could find long tubes but non with air tubes.
Reply 0
Nov 13, 2004 | 02:03 AM
Don't think you'll find emission legal longtubes. I think maybe only hooker super comps will be the only ones.
Reply 0
Nov 16, 2004 | 10:57 PM
is there any way i can drill and add smog tubes? i just need to pass visual inspection.
Reply 0
Nov 16, 2004 | 11:05 PM
Get the SLP shorty's, you can get them for 400 easy and 360 or so if you try, 1 3/4 non air, the air setup is different on an LT1, then add the fittings like the SLP LT1 set, take a look at their site for pics of the LT1 set and you'll see what you need to add.
Reply 0
Subscribe
