Swapping In a Carb Motor Need some Advise
Old Nov 14, 2004 | 01:17 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
HI All,
I am pulling out my broke LO3 and putting in an early '80s 305
I read the swapping EFI to Carb tech article and I still have a few Questions.
First off I am putting in a semi built 305 that was in an El Camino
It has a rebuilt TH400 tranny so I am keeping that. I Think All I have to do is hook up a vacume line from the Manifold to the tranny right? (just like to old one?)
The engine did not come with a distributor, what kind do I need?
Do I need one with a vacume advance unit or a mechanical advance? Whats the differance?
If you could suggest part numbers that would be great.
Also my friend said I need and Ignition box, like an MSD is that correct?
What kind/model should I get?
I am just using the car as a daily driver so I do Not need anything to high performance.
This is my first motor swap to a carb setup so any tips would be appreciated.
Also now that the computer is not running the motor will my dash guages still work?
Old Nov 14, 2004 | 04:06 AM
bigarmzz's Avatar
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
Re: Swapping In a Carb Motor Need some Advise
Originally posted by TBITrucker
HI All,
you dont need to change your ignition at all....
get an older non computer controlled distributor
the mechanical fuel pump will suck the gas right through your electric in tank fuel pump with no worries
and yes, there isnt a kick down cable on a th400
good luck
-bigarmzz-
Old Nov 14, 2004 | 11:14 AM
ljnowell's Avatar
Well, you do need to change you ignition, the whole system really. Minus sparkplugs and wires. Get an old style HEI distributor, you will be set. The vacuum modulator will need hooked up to manifold vacuum.
Old Nov 14, 2004 | 12:57 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I was given an HEI dist today. It is the Kind with the coil in the cap and a vacume advance. There is also an electronic module of some sort in it.
I am told the unit worked just fine when it was last used about 5 years ago.
It is real dirty and greasy inside under the rotor.
Should I clean it out? or get one of those complete rebuild kits.
So, do I need one of those ignition boxes?
What would be the advantage of using one?
Old Nov 14, 2004 | 01:02 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
what are you planning on doing about the torque arm since you are using the th400?
Old Nov 14, 2004 | 01:28 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Torque Arm?
I am not sure what that is.
I think there is a TH400 in the car now.
When I got it the previous owner told me he swapped in a Truck motor and Tranny from a '90 suburban.
I changed my tranny fluid and filter once and I was given the wrong parts at the auto store. When I went back with the old ones so they could match them up i am pretty sure the guy said I had a TH400.
So if there is one in there now either I dont have a torque arm or they came up with a solution when they swapped the motor...I hope.
Now ya got me worried, I am gonna lift it up and take a look before the sun goes down.
It has always shifted "funny" but I thought that was because I had a truck tranny and the shift linkage was different. One thing is for sure it is a 3 speed.
Old Nov 14, 2004 | 01:42 PM
THEGENERAL's Avatar
Torque Arm?
my bad i didnt read that in your sig there you obviously already have a torque arm relocation bracket on it ....
Old Nov 14, 2004 | 02:59 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I think I found it.
The arm is there. The bracket that it attatches to looks "home Built" so that must be it. I also noticed my shifter linkage is loose as hell and there are a couple of rusty worn out springs that is probably part of my problem. It looks like it was "back yard modified" to fit my tranny. I think I will need to pay it some attention soon.
So how about that spark box? Should I get an MSD 6A or the like?
Old Nov 14, 2004 | 04:08 PM
tommyt's Avatar
Car: 87 T/A
Engine: built NOS 350
Transmission: manual 700r4
No need for MSD. If the HEI works properly, it will be fine without it. Get some
good spark plug wires for it and You'r good. If Your distributor isn't too worn ( no shaft to housing slop) just clean it up
put a new cap and rotor on and try it out.
Make sure the timing advance works OK, check with a timing light...its all pretty straight forward. It is a bit of a hassle, and is not needed in every case, but most people also drop the tank and get the stock fuel pump out. I did it , it is a hassle, but You can always do it later when the rest of the swap is done. In a stockish application like Yours, its not as critical as
it would be with a built motor where more fuel volume is needed...
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
