LS2 motor!!! (Glorified LS1)
All the talk about the LS1 motor swap, now the next
gen of the "LS" series is out! The LS2 in the all new
Vette, GTO and Caddy. Anyone here thinking about
doing that swap? I know it's a little too early, but I
am sure some people are willing to do this!
Just wanted to post this link here for specs on the
"redesigned" LS1. I wish it was pictured in an F BODY
but of course, we may not see that until 2006 or so.
http://www.autospeed.com.au/cms/A_2062/article.html
Here's another link with specs on the LS2:
http://gmhightechperformance.com/features/0405htp_ls2/
Oh, and there will be an LS7 package available too! Imagine
like over 500hp from a factory GM car????? Is it 1968 again?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
a lot of people will/might wanna do the ls2 swap but unless they have large pockets because I don't think you'll find one in a junkyard in less than a couple years
Car: Camaro
Oh you will find em but they will cost a fortune. I will be lucky to get the LS1 swap done before someone with fat pockets gets one in a third gen! Almost had the LS1 too!
I know that they will cost a fortune for many reasons.
Main reason: It's new! But I know there's some thirdgeners
with deep pockets are willing to buy up this new and
improved LS1 motor. If I had waited longer and had
my own garage, I would have done this swap instead
of the traditional gen 1 or gen 2 SBC swap. But, If I
ever get rich some day, maybe I will buy an old 60's
Camaro and swap in a brand new LS2 with T-56.
Actually an LS1 or even a LS6 would be more logical
for me that's on a budget. But, if you want the latest
and greatest, you gotta get the new stuff that's out.
That's a dream now, maybe a reality someday. Just
like how my first project was ( a dream, now a reality!)
I can bet money that GM is cooking up a T-57! Or maybe
a T-7. It's becoming more common to see 5 and 6 speed
autos, so a 7 speed manual is not far ahead.
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
on http://www.sallee-chevrolet.com the
ls1 is $5,995.00.
ls2 is $6,375.00.
is this the engine your all talking about?
http://www.sallee-chevrolet.com/Chev...ckV8s/LS2.html
ls1 is $5,995.00.
ls2 is $6,375.00.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Originally posted by Camaro_nut
I thought that the GTO got a regular LS1 345hp/345ftlb. motor?
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
GM didnt make the T-56.. did they? I thought that was a tremac or borgwarner 6 speed. (maybe I'm wrong.)
.... I can bet money that GM is cooking up a T-57! Or maybe
autos, so a 7 speed manual is not far ahead...
I'd love to see a automatic transmission with 6 or more gears in a thirdgen - that would rock!
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
From Sallee:
In ’05, the new LS2 also becomes the standard engine for the Chevrolet SSR (390 hp / 291 kw and 405 lb.-ft. / 549 Nm of torque) and Pontiac GTO.
Just like i said before,
ls1 is $5,995.00.
ls2 is $6,375.00.
ls1 is $5,995.00.
ls2 is $6,375.00.
just get the LS2 motor then.
But, for a person on a budget it's better to just wait
out until next year when more are on the roads and
get cracked up and sent to junkyards. For a total
drivetrain swap, it's better to buy everything all at
one time. The motor, computer, wiring, trans and
everything attached to them. Besides, it would be
cheaper to buy the complete drivetrain used. The
price of just the motor new would cost the same
for the complete LS2 package with trans. At least
that's what the LS1 motor/trans. goes for on Ebay.
Like between $5K-$8K for everything used.
Originally posted by f-crazy
its 350hp/365ft pounds
Uh yeah...close enough.
On the subject about hp/torque, then what is
a detuned LS1? The older (98-02) LS1s got
between 315-325hp with 345ftlbs. from the
4thgens. So, what would a detuned LS1 be
in a GTO when they are rated at the normal
power for '04? (350hp/365ft lbs.)
Yes, Borg Warner made them. Which I believe
Tremec now makes them.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Whats the big deal about the ls2. Its just a 6.0 Truck block that has been cast in aluminum. I would rather have the truck block because you can bore those out with out the hassles of resleaving. And it only weighs about 100 lbs more.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
it is no big deal. I just wanted to point out about
the new LS2 design that's going in a sedan!
LS2 Details :
Compared to the Gen III-based LS1, the 2005 GTO’s LS2 V-8 incorporates several significant changes to help improve performance. The block is an all-new casting with cylinder bores measuring 4.00 inches (101.6 mm) in diameter. The cylinder heads and camshaft are revised, too, to deliver the airflow necessary to complement the engine’s larger displacement. Other changes include:
New aluminum block casting with revised oil galleries and provisions for external knock sensors – external sensors improve serviceability
Camshaft lift increased to take advantage of increased cylinder head flow
Camshaft sensor relocated from the rear of the block to the front of the block provides room for new oil galleries
Flat-top piston design with lower ring tension reduces friction
Piston floating wrist pins help quiet the engine
More efficient ignition coils require less energy to provide a comparable spark
Compression raised to 10.9:1
LS6 heads
Larger, 90-mm single-blade throttle body
Reduced-mass water pump design with improved sealing capability
Engine “redline” raised to 6500 rpm
Revised and more powerful engine controller incorporates all electronic throttle control functions
Car: '91 Camaro Z-28
Engine: 402 fixer upper.
Transmission: A midget with a fishing rod.
Its nice to see GM moving away from the standard set with the 5.7 (a 5.7 hemi...considering the 1968 hemi was a 7.2 liter engine, can i not help but feel disappointment?) and into something different.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
yall guys are funny, there is a place around here where i can get a complete pan to intake with accesories and coilpacks for under 1k delivered, this is a low mile pull out of a wrecked vehicle which this has a 12 month warranty. then im gonna get the 499 front member for ls1 , bolt my th-350 to it and be done with my swap. complete out the door 2k tops. i might spend 4or 5 hundred and get the block re bearing and ringed so i dont have no probs and then pick a good cam and spring set, cam only ls1 in a thirdgen on a 100 shot with a th-350 should do pretty good
yall guys go ahead and spend your 5 or 6 k on a crate motor ls1, ill get a used one rebuilt and spend half the cash installed and we will see who comes out better, i think it is histerical that yall would even consider a crate gm motor when the salvage yards are full of f-body's and trucks with 5.7's and 6.0's for sale for cheap. there is just a smarter way to go about it and i dont think anybody wants to throw away 6k on a crate motor when you install it and run it you have the same thing........a used ls1
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Have fun rebuilding an ls1. Especialy over boreing it oh wait you cant it needs to be resleaved. New is new not rebuilt
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
anyone selling a ls1 with the wiring and all accessories for 1k would have to be on crack.. buy all u can at that price
and a new engine is kinda hard to compare to a used one
if i had the cash i wouldnt be messin around with a used block that could blow up 10 miles down the road but im gambling with a used setup..
if i had the cash i wouldnt be messin around with a used block that could blow up 10 miles down the road but im gambling with a used setup.. Originally posted by xtremeirocz
Car: '90 RS
Engine: 377 LSX
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
The iron block doesnt have sleaves. Also I dont even think they sell pistons for ls1's that are .010 over. .005 over is like a little more then a hone anyways.
Car: '90 RS
Engine: 377 LSX
if i had the cash i wouldnt be messin around with a used block that could blow up 10 miles down the road but im gambling with a used setup.. Senior Member
the last motor i saw bought out of there was a complete 6.0 longblock for 550. oilpan to intake, the accessories and coilpacks are not more then another 200-300 from them
its a rebuilt piece of crap, i paid about 600 bux for the longblock for this rebuild
i cant post for crap, oh well, here is a pic of her ls1 and my thirdgen im talking about converting.
well i guess best automotive off of mcarty is on crack about 5 times a week
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i know which best xtremeirocz is talking about, i pass by it every day. about 2 years ago they had a complete 2001 LS1 with PCM, wiring harness, exhaust manifolds, starter & trans with drive shaft, it was sitting to the left of the front door as you walked in. they said it had about 20,000 miles on it, asking price was $2,500, if i had the cash to spare back then, my car would be LS1 powered now.
their phone number is 713-676-2137
yep and that was 2 years ago and without a shop discount which i can get, im telling yall guys there are cheaper options
ok, i called up best automotive and best core both on mccarty and found a few deals on stuff, a complete 5.7 oil pan to intake with accesories for 950$ and they say it has 40k on it, they also had a 6.0 with iron heads for a hundred more with the same accesories. they said they had a ton of the 5.3 ls1 's out of the trucks that made 285 and that truck intake would fit easy under a thirdgen hood. im almost thinking of that, those complete are around 650 to 750. anyway, if i pick any of these up , get a painless harness maybe have new rings and bearings put in i could definetely put the swap together for under 2k or around that. now if i could just sell this stroker motor!
well the 5.3 and 5.7 are not iron , the only iron is 6.0's and they are all ls1 design, im sure they have them with tranny and everything if thats what you want, i didnt ask though. ill probbly cruise down there tommorrow or thurs. and see what they got.
yall guys are right i went down there and picked up a 5.3 complete with accessories today
the only thing i have agaisnt the aluminum blocks are that they are so fragile, but they are light as hell.
Car: '85 Z28
Transmission: TH-350
2nd Fastest LS1 in the country belongs to Harlan on LS1tech. he's gone 8.29 or so on a stock ls6 block and crank... weak?
they are fragile, go assemble a few and find out about their bolt threads, and where they like to put coolant that is down in a headbolt hole that you couldnt get out, their crack rods are crap, their cranks are descent. that guy doesnt have a stock ls1 crank and block its a sleeved stroker motor, the fastest stock bottom end ls1 is 9.60ish and was set out at baytown last month
