LS2 motor!!! (Glorified LS1)
Old Dec 29, 2004 | 04:47 PM
  #51
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Originally posted by JOEYZ28
2nd Fastest LS1 in the country belongs to Harlan on LS1tech. he's gone 8.29 or so on a stock ls6 block and crank... weak?
Weak? By all means no. Reliable is my concern. How often does he drive it? I don't want to re-sleeve a motor if it takes a dump. I'll go with the tried and true.
Old Dec 29, 2004 | 05:04 PM
  #52
JOEYZ28's Avatar
Car: '85 Z28
Transmission: TH-350
Stock bottom end record is 9.64...That's stock rods and pistons... Harlan has a stock 5.7 block and crank. I'm sure it's race prepped but it aint no c5r and it 's not sleeved to my knowledge. BIG turbo.
Any time you deal with alum parts you have to be carefull with threads and such but the blocks are plenty strong to take what you dish on a regular basis and worth the weight savings IMO.
Old Dec 29, 2004 | 05:06 PM
  #53
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i dont know, my wifes ls1 only needed a .10 over and she drives it almost everyday and it put out over 600 on gas at mti. my point is that like any motor they have their quirks, but the aluminum 5.7 block is so much lighter then the boat anchor 6.0 or 5.3 . i picked up this 5.3 today and was like damn, i thought they were aluminum too, oh well, i think im gonna see what the machine shop says and go from there. i really just want to put a ls1 in my thirdgen because im tired of all the issues with the controls on my tpi, i would rather have coil packs and ls1 edit then the crap we have to deal with with tpi, i might be wrong and still put my 388 in my iroc, but i am gonna weigh the pros and cons on doing both
Old Dec 29, 2004 | 05:08 PM
  #54
i think its a sleeved all bore then, i know it is suppose to be a 382 and there are two different ways to do that, stroker motor sleeved or stock crank and huge bore. either way it produces a ton of torque for them
Old Dec 29, 2004 | 05:25 PM
  #55
JOEYZ28's Avatar
Car: '85 Z28
Last I looked it was a honed over 348, but he may have changed it.
Old Dec 30, 2004 | 08:43 AM
  #56
maybe it was, but i heard from the guy who built it that it was a 382, just didnt know if it was a stroker or all bore. anyway, aluminum or iron, i would take the advantages of a ls1 over a tpi anyday
Old Feb 19, 2005 | 04:26 PM
  #57
Camaro_nut's Avatar
Just some FYI:
Their are aftermarket iron (LS1) blocks now, too. In case
nobody knew already. Those are capable of 6 seconds
in the 1/4. NOT for the budget minded by any means,
but I just wanted to throw that out there.
Also, the 05 Corvette gets a 500hp LS7! Nice!!!
Old Feb 19, 2005 | 08:30 PM
  #58
1BadThirdgen's Avatar
Car: Trans Am
You won't see an LS2 in a thirdgen for a long, long time..........................
Nice LS1 swap with the supercharger.....
Old Feb 20, 2005 | 01:05 AM
  #59
89FormulaLS2's Avatar
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
You'll see my 3rd gen with a 402ci LS2 stroker this spring.
Old Feb 20, 2005 | 04:44 PM
  #60
Camaro_nut's Avatar
WHY NOT??? There are people out there with the
"Cha-Ching", the time and the place to that swap!
I am SURE this was talked about even when the
LS1 motor first came out in '98.
Orr89RocZ
Apr 25, 2016 08:28 AM
zayne0
Aug 24, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Thirim
Aug 13, 2015 03:09 PM
