Buying a crank from ebay, help.
Old Dec 3, 2004 | 08:40 PM
paul5.0's Avatar
Car: trans am 1991
ok I have a 350 chevy in the garage. The guy I got it from said it was a roller motor. its a two bolt with these casting #'s 14093638. Im looking at a 383 crank on ebay, but im not sur if it is right. Roller motoers came out in 1987 right? I know this engine uses a one peice rear main seal, but the ebay advertisement stats that the crank "is for a one peice rear main seal 1989-98 roller motors." Mine is a roller but not a 89-98. Whats up with that?? can I use the crank? is the advertisment wrong? What is the difference between the gen I, II, and III 350's and what gen is mine? I dont want to blow 300$ please advise.
Old Dec 3, 2004 | 08:57 PM
nsimmons's Avatar
Yes you can use the crank, you have a gen I roller, Gen II is lt1(you can still genII bottom end parts i believe) get III is the ls1. The ad must be wrong.
Old Dec 4, 2004 | 08:37 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Re: Buying a crank from ebay, help.
So ? Its not 3rd gen specific.
Ive got a 1998 3/4 ton chevy truck long block. Gen 1 sbc.
Only f-bodies and vettes got the LS1 those years, trucks still got
usual SBC parts.
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
Old Dec 4, 2004 | 08:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The actual "roller" part has nothing to do with the crankshaft. All you need to know is whether it is a 1 or 2 pc rear main seal (along with the obvious things like mains and stroke).
Yes, any 1 pc rear seal crank will interchange, meaning, the LTx cranks can be stuffed into a Gen. I block, seal depending.
evilstuie
Feb 28, 2016 03:33 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
