5.0- 5.7 computer troubles
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
I have an '86 Iroc clone that according to the vin code use to be a six popper Sport Coupe. The 5.0 that was in it ran great but a little rich. The 5.0 is tpi and looks like an '86 engine (see pic). The swap looks complete and professional as though dealer installed. So I rebuilt a L98 5.7 from an '88 GTA and dropped it in. Street strip cam, mild head & intake port & polish, roller rockers, gear drive, headers and Accel ignition. Now the 5.7 computer won't start the car but the old 5.0 one will. I kept the same harness because the Painless Wiring harness was the same part # for '86 & '88. The '88 computer clips right in. There is also a Bosch unit attatched to the computer w/ it's own harness, what is it? Can the 5.0 unit be programed to run my 5.7 right? The car runs great with the 5.0 computer but I can't help think I'm missing out on some power. Thanks for reading, any help?
I thought the only difference between the two, that mattered anyway, was the PROM? If you have 350 sized injectors, 350 knock sensor, and a 350 prom, it should work. At least thats what all the FI swap guys always say.
5.0-5.7
It won't even start. what the hell is the bosch box attatched to the computer? Is it engine specific? What is the correct way to install a different computer? Am I loosing power with the 5.0 box?
Transmission: 4L80E/4L80E
Re: 5.0- 5.7 computer troubles
Put the 305 stuff back in. MAF is not nearly as sensitive to changes as SD is.
computer troubles
what do you mean put the prom in the computer?
I just installed the box that said ecm?
Maybe I just don't know what I'm doing.
I would like to, if possible install, a adj fuel press reg to make up for the higher fuel demand of my 350.
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
well I think your problem lies with the difference in the ears, the 86 ECM may not have VATS in it but the 88 one will. Vats is what keeps the car from starting without the proper key in the iginition. I think your best bet would be to have either a custom chip done or maybe just try and get one from a stock 86 ecm for the 350 and put it in the 86 ECM and it should be fine.
5.0-5.7
The donor car didn't have a dyode key for security.
KO1
16
Oct 15, 2015 05:00 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
