LS1 valve question
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
LS1 valve question
Does anyone here know the length of the valves used in the LS1/LS6 heads?
I just bought a set of Ti valves on eBay for probably close to their scrap value. I didn't expect to win, but I have the valves now, and I thought I might as well try them out. I'll have to have the stems cut down and put in some keeper grooves .
Did some searches... found nothing
Help out if you can
Help out if you can
Car: '85 IROC
Engine: LB9
So they're the same length as SBC1 valves...
I wasn't expecting that, because in my search I didn't see any numbers that cross referenced.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Somebody on here build some 305 heads with LS1 1.7 RR's and LS1 valves. All they did IIRC was press in new LS1 valve guides.
search for LS1 rockers.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You sure they used LS1 valves? I remember the LS1 rockers, but not the part about LS1 valves...
That was quite awhile ago though, so I don't really remember the thread all that well.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 25, 2015 11:49 PM
