ls1 motor mount question....
Old Dec 17, 2004 | 04:05 PM
black84z28-4spd's Avatar
has anyone used the hotrodlane mount plates with regular chevy motor mounts?...
i saw the set for $140 cromed...
Old Dec 18, 2004 | 12:00 PM
CamaroCain's Avatar
Car: 88 Camaro
Re: ls1 motor mount question....
I have asked the same question in another forum, I was told that they do not work with the third gen because the oil pan location is so critical. since we have to move the mounts rearward a couple of inches so the pan will clear the stock cross memeber. If you have a tubular k-member with stock small block mounts they would probably work.
Clint
Old Dec 18, 2004 | 01:28 PM
ok...then it'd have to use the other mounts
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
