BBC swap, engine mount question
Old Dec 21, 2004 | 03:08 PM
Duke901's Avatar
Car: 89 Formula
When swapping to a big block I know I can use the stock frame mounts, but what mounts should I use on the block. Can I use small block mounts or use the stock big block mounts?
Thank you
Mike
Old Dec 21, 2004 | 03:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You would use stock factory 3rd gen V8 clamshells.
Old Dec 21, 2004 | 11:54 PM
Duke901's Avatar
Car: 89 Formula
So the ones that are on the 305 that came out of the car will bolt onto the big block with no problem.
Old Dec 22, 2004 | 05:44 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Old Dec 22, 2004 | 08:52 PM
Duke901's Avatar
Car: 89 Formula
Sweet, one thing i wont have to buy.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
