305 project
Old Dec 27, 2004 | 12:55 PM
dukemushroom1's Avatar
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
305 project
i was wondering what kind of things can you do to an LO3 to give it a little more juice? the engine will probably go in to a 95 S10 but i'm asking here since it's a thirdgen motor.
Old Dec 27, 2004 | 01:12 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
You could put an LT1 cam in it, with some tuning ..
Get TPI heads, ported and polished,new springs...
shorty headers 1 5/8, shift kit and vette servo.
pick a catback, it all comes out the the sound you want unless your looking for max HP.
Old Dec 27, 2004 | 01:58 PM
firefrombelow's Avatar
Like above said. Id go with some L98 Aluminum Vette heads. They are going for about $500 a set on ebay now. Buy some, and get them ported.
Old Dec 27, 2004 | 04:24 PM
Spectre's Avatar
Engine: 3.0L/183
Im kind of bias concerning the vette heads...
They're aluminium, which is good .. less weight
Tho they have a 58cc combustion chamber..
maybe thats why they make good power .. thus raised
compression.
Vortecs need a specific intake.. carbed isnt bad.. tho injected,its 400$
But they have the new still combustion chamber, more efficient..
And they're proven performers..
for 600 or so, you could get the prepped vortecs..
Id start porting what I have, or find a decently priced replacement
then later on, you could get something better ..
Old Dec 27, 2004 | 05:02 PM
KiLLJ0Y
Guest
Posts: n/a
500$ for aluminum vette heads on ebay?? yeah right.. maybe thats the opening bid, most of these sales end at like 800, because some A-hole started a bidding war in the last 30seconds of the sale.. if i could get a set for 500$, fully assembled, cleaned, and in good condition, i would buy them now.
Old Dec 28, 2004 | 12:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Foget the vette heads on an LO3. Not worth the cost unless you plan to use them on another motor down the road. Plus you would want to mill them since you would only have around 9.3:1 with an aluminum head on a 305. You want a 58cc chamber if it is an iron head. Check out the "new to TBI" stikcy at the top of the TBI forum. It has everything you want to know about modding your LO3.
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
tom1985
Apr 19, 2016 07:55 AM
gta90
Sep 15, 2015 04:00 PM
