v6-v8 swap
Old Feb 19, 2005 | 10:58 AM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
v6-v8 swap
i am swapping a 350 out of a 92 blazer into my v6 83 firebird. can i keep the v6 oil pressure gauge. it reads to 80 and i bought a 80psi gauge for a 83 sbc. also i used an adaptor and put it in right about the oil filter and plugged the hole by the distbutor. will this work. thanks
Old Feb 19, 2005 | 01:52 PM
kevinc's Avatar
Car: 1982 Z28
No problem I can see w/ using the threaded hole above the oil filter boss instead of the threaded hole on top of the block's rear china wall. You'll get a good indication of overall system pressure at either location.
As for using your old dash gauge, no clue. You can find out by comparing the resistance values of the sender you bought (available from the manufacturer) against the resistance values of the in-dash gauge (available in a Helms manual most likely).
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
