406 long block
Old Feb 25, 2005 | 12:21 AM
shouup's Avatar
406 long block
know where to find a 406 long block, i cant find one anywhere?
Old Feb 25, 2005 | 10:24 AM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
I've got one.. Was building it for a boat, flat top pistons, new 76CC heads, RV cam, everything ready to go, What state do you live in??
Old Feb 25, 2005 | 10:28 AM
shouup's Avatar
im not looking to purchase right away, was just checking out prices and seeing if my best option was to have a local shop work on it of see if there was a good choice on the internet. I had a bad experience with buying a motor someone built in the garage so im going to stick to shops with warranty's now. I had a 302 built for a mustang i owned and i blew up around 1500 miles, the rod bearings were almost completely destroyed.
Old Feb 25, 2005 | 05:19 PM
shouup's Avatar
how strong is a remanufactured 400? Im thinking of maybe picking one up and starting from there. Would i be able to safely push 400+ HP out of it? Whats the stock compression for a 400?
Old Feb 28, 2005 | 10:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Stock" compression was about 8.5:1. However, "stock" 400 heads are terrible from a performance standpoint. I had a '70 Impala with a stock 400, I couldn't figure out why going from 2bbl to q-jet and single exhaust to dual didn't help it much. Answer is the heads are terrible (which I didn't learn until after I did some family swapping and my brother had it).
"Stock" rebuild isn't the typical approach from a performance standpoint. Stock had short rods, but 5.7" rods can be used with appropriate pistons, which are readily available. Stock 400 cranks aren't particularly strong, you might want to consider an aftermarket crank.
Check these guys out http://www.rebuilt-auto-engines.com/...45105383085.86 - they don't start the build until they have talked to you about what you're after and what they can do. If you ask for 5.7" rods, aftermarket crank, and better heads, I'm sure they'll accomodate you.
Old Feb 28, 2005 | 08:35 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Would the lg4 heads, or 416(?) heads which is so common, be any better than the stock 400 heads?
Old Mar 1, 2005 | 08:41 AM
five7kid's Avatar
They would flow better, especially with 1.94/1.60" valves and porting work. However, you would need to control compression because of their stock 58cc chambers.
morrow
Jan 13, 2024 12:29 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
