I got a reman 305 5.0, what 2 do?
Old Feb 26, 2005 | 12:20 AM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
Dude Let me ask you a Question.
I just got a reman 305 5.0 with new reman Rochester EME4 installed in my 86 Trans Am, the installer removed all smog and air things. The car runs perfect.
If you had this setup would you try to put everything back the way it was(factory) or would you continue to remove factory setup and get new headers/intake manifold/holley carb/ cat-back system, etc, etc???
Im new to the game
Old Feb 26, 2005 | 09:11 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Smog testing comes to mind. If you have a visual smog check re-install all the components back to factory specs.
Old Feb 26, 2005 | 09:32 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
leave it stock
Old Apr 10, 2006 | 10:09 PM
cheppibear's Avatar
Car: 1984 T/A
Engine: Chevrolet 355
Transmission: Borg Warner
Where did you get the reman engine and carb?
I am looking to do the same thing.
Would also be curious to know what the car does here in NJ on the emissions dyno. i.e. Do you really need the smog pump???
Old Apr 10, 2006 | 11:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
For street duty NOTHING beats the performance of a Q-jet.
Gunsbee
Sep 7, 2015 07:10 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
