LS1 & Tachometer
Old Mar 4, 2005 | 10:42 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
LS1 & Tachometer
How are you guys getting your tachometer to work? I have all of my gauges working but the tach, because my '00 PCM does not have a tach output, it uses serial data to the Instrument cluster.
I have a hunch that the RPM signal the PCM sends to the ABS/Traction module might work, but was wondering what everybody else did. I don't want a big aftermarket tach mounted to the dash either.
TIA
Old Mar 4, 2005 | 10:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not have a tach output? sure it does! thats how everyone gets aftermarket tachs, shiftlights, window switches, ect to work.
its the C105 plug... pin G.. white wire... #10 on the PCM.
its suppost to go out to the brake or traction control or somthing... but its a tach pulse.... a 4cyl tach pulse.
get a converter to double it into a 8 cyl tach pulse for the stock tach, or get a aftermarket tach, and set it to 4cyl mode.
Old Mar 13, 2005 | 08:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I had the right circuit, but wasn't sure because its a low voltage signal (5 volts). I was expecting it to read 50% since it puts out a 4 cylinder signal, but the PCM puts out a 0-5 volt signal instead of a 0-12 volt signal, making my stock Tach read zero. I installed the dakota digital SGI-8 and that fixed it.
Old Oct 4, 2005 | 09:44 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
What output did you use on the SGI-8 and what did you set the 10 switches to??
Thanks!
**Old post, sorry to bring it back up!
Old Oct 5, 2005 | 08:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
you dont need a SGI8.. you can do it now by directly connecting it to the tach..
then you can use HPtuners, LS1edit, or EFIlive to set the tach output to 8cyl mode... or 6cyl mode if you have a V6 tach..
arnt advancements nice? couldnt do it last year, but you can do it now.
Old Oct 5, 2005 | 10:13 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
What about Tunercat?? Can it adjust the tach output?? That's what we're using to tune it... we already have the speedo working w/out an adapter b/c we changed my tire size and rearend ratio in the PCM. I unhooked the SGI-8 for my speedo last night and just hooked the input/output together and it works fine. Now if I can just get my tach working right.
Thanks!
Old Oct 5, 2005 | 10:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Thanks!
ive never used tunercat on a LS1... so i donno..
Old Oct 5, 2005 | 11:47 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Thanks!
You sure you are using Tunercat and not LS1Edit, or HPTuner? Tunercat isn't for OBDII, just for LT1, Truck, and some late model F-body cars.
Old Oct 5, 2005 | 11:52 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Yes it is tunercat its just like the tunercat I used when tuning my old TPI motor... a friend has the LS1 tunercat though... no issue with it whatsoever... apparently not many people know they offer it. He said he can get it for my '04 GTO as well. Works for me
Old Oct 5, 2005 | 01:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
isnt LS1 tunercat = EFIlive??
Old Oct 5, 2005 | 01:49 PM
Klortho's Avatar
Car: 1987 GTA
EFILive apparently will use the Autotap for OBDII, the company is based out of New Zealand
Old Oct 5, 2005 | 02:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the autotap?? will use?
its already out.... has been for awhile.
athough i use HPtuners.
Old Oct 5, 2005 | 03:02 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
I'm confused as hell right now... all I know is we used Tunercat and Autotap I believe... I'm checking with my buddy who is doing the tune to see if we can just change the tach output signal from the PCM. Isn't it weird that my tach just drops once I hit 5k?? Anyone else experience this before?? It's kinda similar to what my tach did when I had the 355TPI in my car with a MSD6A box... I had to end up using a $25 MSD tach adapter to get it to work right... weird
Old Oct 5, 2005 | 09:09 PM
Klortho's Avatar
Car: 1987 GTA
I ment the Autotap cable, sorry
just got an e-mail back from Tunercat, and yup, they have a tuning program for LS1's that is not VIN locked like Edit is, just have to get the definition file for the motor you are working on, and it's very resonably priced.
Old Oct 5, 2005 | 09:12 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Yep, just what we're doing
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
